This one had letters all over the screen and a garbled wizard that only was on the very bottom of the screen.
Started with my usual habit of shorting ic pins and flexing the board.
When shorting pins on the 2114 rams@ ic9, 10 and 11 on the bottom board, I noticed the letters all over the screen changed.
Decided to unsolder all three and put sockets in to test wich ones were bad. After replacing ic 10, the letters were gone and I had a clean screen.
Had a few beers to celebrate and, the letters were back, but different..... Replacing ic 11 did the trick, glad I socketed all three rams
Now I still had the garbled wizard who loved to be at the bottom of the screen and nowhere else.
Decided to shotgun all of the 14 and 16 pin ttl chips with my logic comparator.
While shotgunning, I noticed that the wizard sprite cleans up when I press the 5808 ram between ic 86 and ic 89. Replaced the socket, and we have a clean wizard sprite.
All of the ttls I could test with my comparator checked out ok, except for the ls 161 and 163 chips, which are counters so probably cannot be tested with a logic comparator
I put my comparator in logic clip mode with the universal zif card to check activity on the pins of the 161 and 163 chips.
The 161 chips checked out doing more or less the same on every pin,but the 163@ ic100 was dead on all outputs.
Replacing it, got the wizard back where he should be.
