J
jassin000
Can @MetalliC do Atomiswave port edits?I’d still like Rumble Fish 2, it’s just one code for the extra characters.
Not doubting his skill, just wondering if something about the conversion process makes this harder.
If Atomiswave is on the table, IIRC... doesn't Neo Geo Battle Coliseum have several unlockable characters which there is no code to quickly unlock, and you're stuck with Time Unlock which takes thousands of hours or something ridiculous and doesn't even save if you swap games (at least on the Atomiswave motherboard).Can @MetalliC do Atomiswave port edits?Not doubting his skill, just wondering if something about the conversion process makes this harder.I’d still like Rumble Fish 2, it’s just one code for the extra characters.
Also back to Naomi, the four boss characters in CVS2 aren't playable in the arcade version from what I can tell.
+1 for NGBCIf Atomiswave is on the table, IIRC... doesn't Neo Geo Battle Coliseum have several unlockable characters which there is no code to quickly unlock, and you're stuck with Time Unlock which takes thousands of hours or something ridiculous and doesn't even save if you swap games (at least on the Atomiswave motherboard).Can @MetalliC do Atomiswave port edits?Not doubting his skill, just wondering if something about the conversion process makes this harder.I’d still like Rumble Fish 2, it’s just one code for the extra characters.
offset old new
0014945C: 00 03
00149470: 00 03
00149484: 00 03
00149498: 00 03
001494AC: 00 03
001494C0: 00 03
001494D4: 00 03
001494E8: 00 03
0022D804: 00 03
0022D818: 00 03
0022D82C: 00 03
0022D840: 00 03
0022D854: 00 03
0022D868: 00 03
0022D87C: 00 03
0022D890: 00 03
offset old new
001487FC: 00 03
00148810: 00 03
00148824: 00 03
00148838: 00 03
0014884C: 00 03
00148860: 00 03
00148874: 00 03
00148888: 00 03
0022D804: 00 03
0022D818: 00 03
0022D82C: 00 03
0022D840: 00 03
0022D854: 00 03
0022D868: 00 03
0022D87C: 00 03
0022D890: 00 03
@MetalliC can you please explain how will I change the offset ?Power Stone 2 items and char unlock patch:
please test and let us know if it worksCode:offset old new 00004BB2: 0F 05 00004BB3: C9 E0 00004BBC: 0F 01 00004BBD: C9 E0
Thanks,I've never used HEXedit, in WinHEX you may open PowerStone2.bin then click Navigation - Go To Offset (or press Alt+G) then enter file offset hexademical number, then change old value to new value.
or simply scroll down until needed file offset.
I'm at work ATM, I'll report back with screen shots soon as I'm home.it works fine here at emulator, I was more interested in test on real Naomi
Super small, but I think it will help.maybe we should make a small tutorial to edit hex files. Any volunteer?
offset old new
00004BB2: 0F 05
00004BB3: C9 E0
00004BBC: 0F 01
00004BBD: C9 E0
Tested this and it works perfectly fine. Love the boss modeokay, simpler task first:
Capcom vs SNK2 unlocks patch: single match mode which can be set in game test mode, and fight vs all bosses mode (on title hold MP and MK then press Start)
for Capcom vs SNK 2 Mark Of The Millennium 2001 (GDL-000
Code:offset old new 0014945C: 00 03 00149470: 00 03 00149484: 00 03 00149498: 00 03 001494AC: 00 03 001494C0: 00 03 001494D4: 00 03 001494E8: 00 03 0022D804: 00 03 0022D818: 00 03 0022D82C: 00 03 0022D840: 00 03 0022D854: 00 03 0022D868: 00 03 0022D87C: 00 03 0022D890: 00 03
