SEGASHIRO
I concur...but I can take the F3 first!PGM Multi, for these reasons alone:
Ketsui
DOJ
Espgaluda
If the pgm multi was only compatible w/ these 3 games, I'd be, as grateful, indeed.
Ketsui
DOJ
Espgaluda
. Perhaps a 5-in-1 demonfront/ddp2/ddp3/ket/galuda cart or something to that extent can be done.CPS1 would be incredible2- CPS1: Because best arcade platform ever
Isn't that a Wii based system?what about a multi for the system Tatsunoko Vs Capcom comes on
Well, a little birdy told me that Saturday there might be a big announcement about this new multi!what about a multi for the system Tatsunoko Vs Capcom comes on
noneWhat other games are on that platform?
I just connect my Wii to the OSSC, and connect my pad-hacked VC-pads+Wiimotes inside.what about a multi for the system Tatsunoko Vs Capcom comes on
yes yes we know oyu have a OSSC jassinOSSC
jks
Diamond LCD only accepts VGA or DVI, no RCA/Component.why do you need to connect the Wii to the OSSC? You should be able to connect it direct to the panel, as long as the panel supports 480p
Far as I know the DVI port only accepts digital, for the simply reason if you wanted to use analog you would use the VGA port (but I have not tested this).Does it accecpt DVI-I, DVI-A, or DVI-D?
if it's I or D then you could just use a HDMI adapter from a WiiU.
Failing that have you tried the Mayflash VGA cable for Wii?
