Gonvergub
Eu
Hello, wanted to ask someone more experienced about an issue i have with this small crt. The image is uneven at the horizontal edges top and bottom as can be seen inf the image. I have tried using the service menu, but none of the options there seem to affect it. Best thing i did was change the vertical size to somewhat stretch and hide this, however whenever the image size changes between games or a cutscene plays ins a smaller resolution it can be seen again. My question if this is salvegeable and worth fixing, or if its a sign of overall tv failure being close and that i should start looking for a new one.
You can't fix that with the service menu. The deflection yoke needs to be adjusted
I wouldn't bother, and it's not a sign of the TV failing.
Hey thx for input. You wouldnt bother because process is dangerius/difficult or that it will not deteriorate or affect anything?
Whenever you mess with the yoke you can absolutely make things worse.
