yes interesting ,show us your researchYep, everything lines up with the system I have. I was able to fix a boot cycle issue with that manual. I can send pics if you'd like!
![Astrocity [astrocity] [astrocity]](/styles/default/xenforo/smilies/gaming/astrocity.gif)
Does Anyone know if it is possible to use Jamma connection with X4 , i try a Jamma to USB adapter but when starting my X4 Image on JVS mode it won't reboot .
I have a love live that's stuck in a boot up loop issue. The fans spin up and as soon as that dip switch card green light comes on, the fans all stop and it seems to reboot and repeat the process. Is that similar to your issue and is there something you did with that dip switch card to fix it?Tracing back the weird-looking card with 4 dip-switches, I realized it was connected to the power switch/reset switch pins. So then I traced it to the power switch button and found which pins to short resulting in the machine turning on when it had stopped turning on.
ALSO, I repaired the GPU by replacing its fan because its ball-bearings were really worn down. It sounds silent now and has a fancier look since the fan is from a newer GPU model lol
https://yubi.moe/pics/
