(SQ ARCADE) MiSTer FPGA TO JAMMA/JVS/SNAC-DB15 - MiSTer for JAMMA/JVS/SNAC-DB15 Arcade cabinets
You can use the app or just plug a keyboard usb in ..
Then on the main menu go to controlls setting or load your game core then bring up menu and choose settings controller settings .. or is a direct clone of the pcb
So it will have service and test button waiting to be assigned
Hey I registered for an account because I bought this (well it was a Christmas gift, technically) as well as the DB15 SNAC adapter and couldn't get any of it to work aside from video. But, over the few days it took to get the account approved, I actually got it all sorted, mostly.
I'm using a MiSTer Pi (Taki Udon's DE-10 Nano clone) with 128MB RAM. I'm using a standard MiSTer Fusion setup (not using the Micro SD card that came with the JAMMA adapter). I'm not using the USB 3.0 cable, just plugging the a standard micro USB cable from the JAMMA adapter into one of the standard USB ports on the USB hub of the MiSTer Pi. The only changes I needed to make were flipping SW0 on the main MiSTer board (which made audio work) and uncommenting the no merge vid and pid that were mentioned in this thread. The controls work perfectly as USB (since I'm not using them as SNAC), so I probably don't even need the DB15 adapter plugged in, but one major benefit is the composite sync port which lets me use my GunCon 2 as a light gun (in any core).
I do have some weird audio issues (connecting straight to the speakers via JAMMA edge), it'll start off normal volume but kinda pop and get a lot lower and stay that way, though certain effects in games cause short volume boosts.
The other issue is that none of the buttons from my test, volume up, volume down, service button harness are recognized. I imagine that's because they aren't technically "controller" buttons. Not the end the world, most cores support free play or only use a couple buttons so I can map to one of the four buttons per player, but if anyone knows how to get that working (and which cores actually support it?), that would be great.
Those two issues aside this is a great device and I'm very happy with it. I have it installed in my Mace the Dark Age cabinet (which I previously had been running a Neo Geo MVS single slot).
@FunFortress Retro Game Or @1credit or @MongoTX do you have any advice to get the service/test/volume buttons working? I would imagine if I use the RCA out and and amp then the audio issue probably goes away, I'll try that later this week.
DB15 SNAC适配器需要特殊处理过的系统和RBF核心。普通系统不能使用DB15适配器。
github搜索 MiSTer-DB9可以找到对应的系统文件。
please use language translate this chinese. thank you
关于声音问题,我猜是您的mister主板上面有一个开关状态不正确。尝试拨动那个音频切换开关,用来切换PWM音频和I2S音频。如果方便的话,请拍照您的Taki 主板正面照片给我,我为您指导具体是哪一个开关需要切换,音频才能正常。
控制部分,您需要连接usb桥接线从mister jamma板到您的Taki主板,然后MiSTer.ini里面 0x045E和0x028E前面的分号删除并保存。
please use translate language this chinese. thank you
Thank you. I think it may just be a bad audio amp on the board, but it's ok. I installed a different amp and use the RCA jacks and that works perfectly. Thanks for the response, I'll look into the DB9 MiSTer version, but even without working as SNAC I'm quite happy with the product! Question though - if I use the DB9 version and SNAC, will I need a different controller to access the menu? Right now I have that mapped to Up + Start.
您好,DB9-SNAC不支持控制菜单,因此,您仍然需要一个额外的usb手柄来控制菜单。
please use language translate this chinese. thank you.
@FunFortress Retro Game 您好, 我想買這個產品但是我沒辦法在閑魚或是掏寶上購買。 我還有什麼辦法可以買到嗎? 我會用Mister 然後搭配一台New Astro City 的筐體。 很期待可以重溫小時候在電動間的回憶。
我有使用MisterPi 的經驗 因此我猜應該可以完成這項工作。
您好。可以在AliExpress 买到。店铺名是: FunFortress RetroGame Accessory shop
mister jamma and QMTech main board,拿到手就可以玩。价格比de10 nano便宜。
如果您只购买mister jamma板,它可能可以用于您的mister pi主板,但是该mister jamma板是为de10 nano and QMTech 设计的。当使用在QMTech主板上面的时候,有一个接口转换板附带,请您购买的时候明确说明用在哪一款 主板。
Lol I just hand-made myself one of these DB15 to SNAC jamma adapters with a gold finger, some DB15 terminals and an antoniovillena db15 snac adapter. Then I saw this additional board for sale on aliex, but now its not available anymore.. So nice to not have USB in the way! (for the supported cores anyway). SNAC is definitely the way to go with Mister!
Years ago, I bought some of these Jamma IO boards from this thread, didnt really like them much. I misread the aliex advert and thought it did SNAC built-in, but it did not.. Meh
EDIT: I was asked about this, so here is the long-winded mad method I have used to get SNAC or USB connectivity with my cabinets buttons and joysticks..
I have a cabinet with jamma connection, which in this case, i only use to interface with the buttons and joysticks.
from that jamma socket, i connected a goldfinger, which I then wired two DB15's to, in the neogeo/arcade pin layout. Then I connected those DB15's direct into the Villena's SNAC adapter.
so now my cab can use the joysticks and buttons as a SNAC/DB15 joystick in Mister cores.
As for the video, I happen to be using a Sony CPD G520 PC monitor in my cab, so it takes VGA (but I actually use an HDMI to VGA device from my mister, then I connect that VGA output to the SOny monitor). then I just connect audio analogue out to the speaker system in my cab and wallah - mister cabinet.
For other non snac DB15 Joystick cores, I move the DB15 plugs out of the Villena device, into a daemonbite arcade DB15 device (or two for 2 player), so that then goes into the mister as a USB device. this way I can use my arcade cab buttons and joystick for all DB15 Joystick cores, then all non DB15 Joystick cores too.
Wanted to thank you for sharing this! I also got running on Taki Udon’s board after a few hours of troubleshooting. I was following all the config tips in this thread and for the life of me could not get the controllers to work, even on a new install of fusion.
Thanks to going over your setup I triaged that the micro USB to USB connection daughter board is a little picky on cables on my unit! Had a 1” and 2” micro usb that worked on other devices that did not work and just pulled a different 6” cable to test and kicked right in
Sweet that's awesome. I did run into a new issue a while back where certain cores that used more power (especially N64) would reboot the MiSTer Pi, and I trouble shooted it to being me drawing too much power from the USB ports on the JAMMA board. Moving all of my devices (USB Wi-Fi card, wireless adapter for my keyboard) to the USB hub that the MiSTer Pi Turbo Pack shipped with 100% solved the issue for me...just in case you run into something like that.
Hi guys,
my jamma/jvs expander for the mister is having an issue, where player 2 has got 2 buttons that are not working. When I removed this expander board and hook it on to my computer to trouble shoot(connected to the joystick on my astrocity), i noticed button 7 on player 2 side is not activated, compared to player 1. See screen shot below. Can anyone suggest how should I go about repairing this? I connected my joysticks to another board and do not have this issue, so I am pretty sure it has something to do with this expander board. It was working fine, not sure what happened.
So does anyone have buttons 4/5/6 working using the 8-pin header? Now that Mortal Kombat is working in MiSTer, I'd love to put this in one of my Midway cabinets. Right now it's in a Neo Geo cab (which is, ironically, in a Mace the Dark Age [Midway/Atari] cabinet), and buttons 1-4 work as they should, but MK uses a kick harness...
Oh wait I was thinking about the thin 8-pin header that runs perpendicular to the JAMMA edge on the left side, but there's also a JVS/Astro City header, going to build an adapter to use that.
