I’m sorry, I don’t remember. It was several years ago when I did that setup.@ShootTheCore where did you find pcb feet in black?
I believe you can do either configuration. I don’t have the cart in front of me to confirm.Working through the install now using the manual.
I can't figure out something about the reset lines. The "Connectors" section (manual page 2) implies either P4 or P5 should be connected to the ST-V and the other to the multicart, but I can only find instructions for connecting to the multicart (the pin under the red dot on page 6). The only wire I have connected to the ST-V is the connection from the multicart pad in the blue circle (page 6) to IC12 on the ST-V.
miisalo's video in the first post and twistedsymphony's reference image seem to be built against different instructions. In their installs, the multicart pad in the blue circle wasn't used at all, and P4 or P5 was connected directly to IC12. Should I just ignore the instructions and do that instead?
Do the physical jumpers still work?Thanks @everten. I'm using your ST-V stereo IO board too, BTW!
The selector shows a game list and can trigger flashing, and auto-reset happens at the end. But after reset, regardless of the game I selected, I'm always back to Cotton Boomerang, the last game I flashed using jumpers. I'm using a 12-pin ribbon cable and made sure the marked pin is on the left on the multicart and on the right on the LCD selector. I've also tried reversing the ribbon cable connector on the LCD selector just for good measure, but the behavior is unchanged. Is there something obvious to try before I just wire up 12 Dupont connectors?
Do I need to program the Arduino? I bought it recently (a few months), and it looks like the last update was in 2019, so I'd assume that would be unnecessary.
Is the LCD selector somehow reading the contents of my SD card to show the game list, or is it preloaded with a list of games that may or may not match the 2019-09-13 Darksoft STV pack in the SD card in the multicart?
Yes.Auto-reset function was updated later for the selector (didn't exist in the first batches). It might be possible that you have older program there. The Cotton stays still same if you power off the board and re-power it?
Good question. No! I'll move this to the Darksoft support thread.Do the physical jumpers still work?
FWIW, the ST-V motherboard originally came with black PCB feet as stockI’m sorry, I don’t remember. It was several years ago when I did that setup.![]()
Thanks, I'll try that tonight. I had assumed the SD card was fine because it's the same one that worked well previously.To me sounds like an issue with the cart reading the SD card. If the cars is not there or unreadable it will always boot the last game loaded.
