DARKSOFT Taito F3. Instructions and videos.
Looks like I better work on making my mainboard region free.
Grind dem pinz out with a Dremel tool and the ball shaped bit!
I used a Dremel 106 bit
a Dremel 4000 tool
and a flex shaft attachment.
With this you won't break the pins, if you want to break the pins (for whatever the reason) then use a wider diamond/tungsten bit.
Hmmm cant decide whether to drill the plastic out or use a soldering iron and melt the plastic, any opinions on which is better?
definitely drill the plastic. Don't use soldering iron for plastic. I tried once and it became a mess!
This^
It's easier to grind the entire structure pins and all right out.
Do NOT use a solder iron (or any other heat source) in an attempt to melt the plastic!
is removing the three pins mandatory ?
because I have only japanese games and board and I'll use the same motherboard with the multi coming next week :rolleyes:
The board's plastic tab in the connector needs to be removed at a minimum... Full pin removal is done merely for ease/convenience.
Yes it's actually harder to carefully cut/grind away the plastic from around the pins Vs grinding it all flush.
The reason being the multi hasn't got the matching/corresponding holes for the plastic tab, the pins however are fine.
Thanks for the answer
So it can be done with an exacto and a lot of patience and time
Because using the dremel is frightening to me :/ I would like to avoid to mess up with my board
Using a dremel is the most effective way to grind the tabs off, keeping the pins or not.
Don't even bother with a soldiering iron or a hot knife.
I used an Exacto knife myself - power tools and I have a mutually destructive history together. :D
I used a craft knife and flat blade on a soldering iron. Came out looking nice. All pins intact. Stinks a bit. Missus unfriendly...
Lol! No. Missus guards all of the sharp objects in the house... Ready for when I am the target!
