bagheera369
Also they said on AO wiki that it could be melted out with a soldering iron as well....so I would agree, and put the region free mobo responsibility on the customer.
While I'm totally comfortable burning mine out with a soldering iron, or handling an exacto, if you've done this a dozen times maybe you could post some details about your preferred method?yes i did.
Thanks for posting this werejag, I will be trying this exact method...i used a dremel diamond bit and excavated the pins. this made short work on the plastic wedges. the really small ball type worked out well
But fun for life106 is good,I just did the mod with it.
It just takes time, it's not a 2 minutes thing.
So just to clarify, the pins that make up the region "protection" tabs are not connected to/needed for anything?Performed "surgery" on my mobo as well...
I'm going to just go ahead and start referring to this as "the werejag method" because I did it with a Dremel tool using the bit 191 as described.![]()
Sure it was a little big, but I hit it from the side vertically, and slid the tip forward/upward slowly, cutting/eating away the plastic tab and metal pins at the same time.
