Ok, need some feedback on the rgb version of these, do you guys want:
On the controller(s), would you prefer:
- Top & bottom to be rgb (would most likely require 2 controllers or maybe a custom solution)
- Top white / bottom rgb (could probably be controlled by one controller, independently)
- Top only rgb (one controller)
- Forget RGB, and do both in White, with the bottom leds having a controller, top always on
- RF
- IR
- Bluetooth
- Wifi
- Bluetooth and Wifi
as so far all I’ve seen are led strips hooked up to IO for power.
I need to find where to source the right acrylic and the reflective edge foil.
