Semload
RESERVATION LIST :
01_VJP
02_
03_
04_
05_
06_
07_
08_
09_
10_
20_
START PRODUCTION
Looks great!
Two questions.
Can I see a picture of front where the JAMMA edge is?
How are the DIP switches handled?
Do you have a photo of it front on. I’m trying to see how you’ve implemented securing that part of the stack together so it doesn’t come apart?
Either I’m not following, or you’re not?
Can you show me where the JAMMA connector is. If it doesn’t come off, how is the user meant to connect to their cab / Supergun?
As you know the CPS-1 Multi is like the CPS-1.5 boards. I want to know how you’ve secured the filter board to the case?
You're right, but unfortunately I had to take those photos quickly and disassemble the case because I had to return the Multi CPS to my friend Aldo from "Save Your Games".seems like it would have just been easier to show a pic with the panel off as now im curious what it looks like.
Wasn’t obvious from the photo. Was wondering if there’s some sort of mechanism holding it on place.It is obvious that it comes off. I wrote to you. It is a removable panel with magnets. It comes off, you connect the jamma, when you stop playing, you close it again. The pcb to the case is fixed with steel spacers to the base. You can see it very well in the back photo of the case. Now it's clear?![]()
Owning some of your other cases, I know you e got unique ideas. So was just wondering. Clear about it now.
Is there any way to secure the filter board in place on this design? It’s one of my pet peeves of the multi, how it has a knack of coming apart easily or getting misaligned.
Yes, now I understand. Look, I can put blocks, but from what I've seen and tried, that panel, it's firmly inserted on the jamma. I think you bought the kit from my friend aldo of "Save your games" and I created this case, using that very kit, mounted on one of my cps. So, I repeat, from what I have seen, the filter is firmly on the jamma comb.![]()
On a genuine CPS-1.5 case, the filter board (green pcb pictured) is screwed in, so it doesn’t move around.
For me, the feature of securing the filter board in place would be the primary reason for casing the multi.
@Semload - I actually distribute the products in Australia. It’s the same kit that Aldo and highscoresaves sell though.
The filter board does indeed have a tendency to get dislodged and not flush. I have a few multi setups and the JAMMA finger getting stuck in the JAMMA connector and the filter board moving about are two of the main annoyances for me. But maybe it’s just me?
Case looks great by the way. Thanks for your consideration.
What dip switches are you talking about? Those above the card? Then as I said, the filter is fully accessible. There is a lid with magnets that peel off and stick on.Keeping the filter board attached is the only reason I've been looking for a case. The proposed design, as is, would only make the filter board more annoying to deal with by hiding it in a box. Couple that with no consideration for dip switches, the screen being inside, and the pots being harder to access, I'm not sure what this is for. To put on a shelf maybe.
No need to yell in bold.What dip switches are you talking about? Those above the card? Then as I said, the filter is fully accessible. There is a lid with magnets that peel off and stick on.
Screen is not inside, detaches when using and reattaches when storing. Have you seen the video? And the other potentiometers are accessible. I don't understand where the problems are. I had it supervised by the person who sells these cards in Europe and he said it's perfect as it is, he only suggested I make those two potentiometers accessible and so I did. I also created a 3d element, as you can clearly see from the images.
