bartre
Maybe consider gluing it back.I had similar issues with the bridge being really hard to mount compared to a ribbon cable. I've had to take my kit apart quite a bit due to issues with connections (still not working) and I've bent those pins a few times trying to get them to line up properly under a lot of force.The only part that was troublesome for me was connecting the smallest connector piece between the two PCB's. For me the smaller PCB sat lower a bit and was starting to bend pins. I had to raise up the smaller PCB to half inserted so it would be flush with the large PCB, then sit the connector on then and push it all down at the same time.
Hey @DarksoftHi Anthony,
those wires don't look very neat in my opinion. There may be some undesired solder contact there.
First of all, please unplug the 4 wires that go to the b Board and try loading a game that works without battery. There are many of them. Just to be sure, the KEY file in the directory of the game must be full of 0xFFFFFFF
If that doesnt work, then make sure that the join between both boards of the kit is properly sitting and in the right direction. Test with a meter.
If none of this works, I'd suggest that you sent to @Mitsurugi-w so he can have a look.
That should be enough, if still doesnt work, then remove the cables, they may be doing a short. Also inspect for solder blobs that may have follen during the installation process.If I just unplug from C9 is that enough to test decrypted roms or do I need to remove the wires as well?
Yes, but has to be named "key" and be 20 bytes in size.As for the key file with all 0XFFFFFF, I'm assuming that's the same as the NoBattery.key on the site.
Exactly that.Also, where should I put the probes from my multimeter to check connections between the boards? Am I just looking for continuity.
No worries. We've all been learners.Sorry for all the NOOB questions but I'm a bit new at all this.
Congratulations! I'm glad that you got it done!Thank you to everyone for all your contributions to this thread, if not for all your work I would have thrown all this shit at a brick wall 2 days ago. Hopefully my experience will help some of you that are still having trouble.
