The Jassifier
  • Thread starter Thread starter jassin000
  • Start date Start date
Am I right in thinking the Jassifier will make the video levels from it safe to use with an OSSC?
That device appears to already output proper SCART video levels (ie you don't need a Jassifier with it).
Jassifier was designed specifically for use with the Jammifier, it can be used in conjunction with other devices but is only needed if the video output is raw/directly from the arcade PCB.
Oh really? Looked like it was just passing the jamma signals straight through.
Does anyone have a kit and materials for these handy? These things are gonna be awesome for hooking up HD CRT monitors to cabs.
Thanks @jassin000 for creating this design..
I have like 4 or 5 completely built boards where I was trying to diagnose an issue thought to be with me building them. Turns out, my dumb ass forgot to turn on the +5V switch on the Jammafier. :facepalm: They're all fine, I'm just a blind idiot.
If you want one, you can have one. Just cover shipping. I want 'em gone.
EDIT: They're gone.
Thanks alot man. I'm trying to return the favor and order x4 part kits and solder them for future VGA tube users..
The trim pots on the BoM are backordered until May 2022!
Does anyone know of a suitable replacement? None were recommended by digikey..
I think using a solid resistor at about 600~800 OHM range should do, my pots are dialed in to about halfway (or better) most of the time and for most PCBs this is perfect.
I have 5 wires coming from the "Arcade Cabinet" kit. RGBs and Video ground..
If I were to just wire the signals through hole instead of soldering the VGA hat, Would these be the appropriate holes for my "arcade cabinet" wires?
Does somebody have an updated link to the digikey BoM? The link in the OP is dead.
