Chassis off YAJ are hit or miss. I've bought... maybe 5? Only one worked.
@kazuo thanks, can someone point me to where the hot is on this chassis?Check the fuses. Check the HOT. Check the board for roasted components.
@nem I bought it from YAJ. The auction didn’t state if it was working or not sadly.
Really? I have a original Tosh tube with the PD1843 chassis and this pot has zero effects on the focus.No, that's not right. If you have the standard Tosh tube paired to a PF (A68LTF356X) you can further adjust focus with it. The difference is very subtle, but it is there. It's due to the voltage divider that has been installed in the neck.
Well, now you at least know it can make a difference on the tube that you have. Doesn't mean it will make a difference :p
Bought 7/ 2 workedCheck the fuses. Check the HOT. Check the board for roasted components.
