midwaydj
let me know if you need more photos. I just tried again using my 32gb sd and I’m getting ram error on most of the decrypted ROMs after flashing. So at least we can rule out a/b board connectivity.
This might sound stupid and far off but: Did you check your +5V? I get errors like that if my power supply is set lower than 4.8V. Might be worth checking.This is what I get after I load mvsc unlocked. It faintly says ram error although not sure it will show up in the picture. Also is says writing key on the lcd after programming.
Weird. The small pcb is usually very tight once it's plugged in. I've never seen one be loose since we released it. Does the small pcb have broken pins? Are you sure they are all pushed in all the way?I have clamps for the a+b board but not a clamp for the dark soft kit. Am I
missing something? The smaller dark soft board is the one that I have to clamp down to the b board in order for it to work. ill try some de-oxidizer when I remove the kit again.
Oh I misunderstood. I thought you had problems connecting the game board to the main board not the main kit board to the B board. There is no clamp there, no. But if you have clean sockets and press it in thoroughly it should hold with no problem.I have clamps for the a+b board but not a clamp for the dark soft kit. Am I
Thanks for your help but to me SWD5 isn't used anymore if using the key writing functionality.hey mate. I cant be of help with a key writing setup, however i used an early rev board for my kit (cant remember if it was rev 3 or 4) and can help with some info on the jump wire and swd5
I switched to a g pal, and set up the jumpers as required to suit (soldering, cuting traces if needed, testing for continuity with multimeter etc)
I then setup a wire on the bottom of the board as you have mentioned yours had already... My games booted but all still had scrambled audio. I had to end up removing that wire completely, lifting up pin 9 from the g pal so it didnt go into the socket, soldering a wire to that pin 9 and connecting it to the multi kits j17. Audio was perfectly fine after that...
Swd5 is for auto reset after the game programs. For me one end solders to SWD5 on multi kit. The other end solders to B28 on CN1 on B board, though there have been other cleaner ways to do it since:
Important Info About the CPS2 Multikit
However if you go to the new firmware and key writing method it appears swd5 is no longer required to be used as per here...
New CPS2 Multigame Firmware with Key Writing!!!!!!
PC obviously, I mean I followed all the steps carefully, I put all the chances on my side (PC formatted card, used the recommended memory card, actually have tried 3 of them) and still it doesn't work...That behavior doesn't have anything to do with the jumpers, pal, etc. Usually that problem is caused by the SD card, the way it's set up, or a problem with the files. Are you using a PC or a MAC?
Maybe it has the latest firmware but for some reason it doesn't work.I would be surprised if you got an old firmware, not sure how it could be even possible. In any case, the firmware can be updated just copying one file into the microSD. See here:
Make sure that you copy the files to the microSD in one copy+paste move on a freshly formatted microSD.
