Brandon
Will there be anymore firmware updates for this?
Anyone know the answer to this: COIN is mapped to SELECT-BACK or HOME?
EDIT: For my purposes, I will use SELECT-BACK for COIN as older consoles don't have a HOME button.
Just encountered the EXACT same issue with the EXACT same setup (CPS2 digital av out + IO Board) today at my locals, one of my decoders seems to have diedHi all! I've been having some decoder issues and would appreciate any suggestions
So I've been using UD-USB decoders for a while and they've worked great for me at home, but the past few weeks I've been taking a CPS-2 setup to locals and I've had two decoders 'die' on me (dead as in the status light is off and no inputs are registered). The first one I put down to a chance failure, but now a second one's gone I think something is up and I don't want to burn through any more adapters if I can help it.
Both times the issues started when sticks were being switched over. The USB connection would seem finicky - the LED would be off, but jiggling the USB plug and getting it at just the right angle would cause the light to come on. Later it'd seem completely dead. The first adapter briefly start functioning again after a couple of weeks, so it wasn't completely fried, but now it's unresponsive again.
First thing I want to check just to be sure: it *is* fine to hot swap sticks, right? I haven't seen any warnings not to (or maybe that's such an obviously bad thing to do that no one mentions it)
If it's a physical issue with the USB port, is there anything I can do to get a tighter connection?
And generally, has anyone else had issues like this? Should I be suspicious of my setup? It's an HDMI modded CPS-2 with an IO board powered from a standard laptop power supply. If I plug the adapters into a minigun powered by a proper Mean Well arcade PSU then I see the same issues (but maybe the adapters got damaged by the first setup?)
. Was switching between a few sticks, maybe 3-4 at most when it unfortunately had seemed to give out. Confirmed it wasn't my db15 ports as the one decoder still works in both.They are in stock right now.need another one ! Any restock soon ?
Omg looked a few days ago and it was sold out ! ThxThey are in stock right now.
https://paradisearcadeshop.com/products/undamned-db15-usb-decoder
Yes, that's a common combo, works fine normally.Do the undammed db15 to usb work with Brooks Universal fighting board? I keep getting the blinking green light and when I press the buttons to remap, nothing happens just blinking green light. I'm on the latest firmware for both devices.
What button do I have to hold to put it in ps3/360 mode? Switch is hold k1 I know that much but I can't find the button combination ps3/360.Yep I use mine with Brooks UFBs and no issues
At the time I got mine you did have to connect the stick in a mode (hold down a specific button while connecting) on the UD-USB - I connect mine in PS4 mode
I don’t think it matters with later firmware but just in case yours is older try booting the UFB in a specific mode
My brook wireless board is P1 P2 K1 K2 for PS3, PS4, Switch, and PC (I think in that order, not positive at the moment).What button do I have to hold to put it in ps3/360 mode? Switch is hold k1 I know that much but I can't find the button combination ps3/360.
Which decoders do you have, the block ones or the ones with the enclosure?@undamned Is there any way to tell if a decoder is bricked? I busted out my supergun yesterday at a local and both of my decoders were completely dead (no lights, no inputs registered). Luckily another person had two extra decoders (what are the odds) and we were able to use the setup for the tournament. Both of my decoders had been sitting in a box unused for months, so not sure what could have killed them.
