Still Green
It’s still a no go
moved the wire over to pin 6, adjusted the dip switches, and the problem still persists
. It seems like only dip three actually changes anything. Dip 6,7,8 seem to do nothing for me on or off
Huh. I would’ve bet that was the issue.
Try setting your dips to this and report back:
You need to check on the splash screen, the firmware version should be displayed there.Thanks bud. Will try adjusting the H phase pot later today after work. 991-9015-02 is the number on the UVC board. The manual I am referring to says revision 2.01 dated 1/23/04 https://na.suzohapp.com/images/pdf/uVCUserGuide.pdf
Not using mine yet (almost there), but I aim for about 5.05v usually.What do you guys have your 5v set to when using the UVC?
Yes, you could do that.If I were to combine the H&V Sync could I just use a jumper wire on the 5&6 pins on the UVC?
Edit: actually it was an older revision that had Ground and Horizontal pins swapped.
https://service.globalvr.com/troubleshooting/uvc.html
Yours is the newer version
I don't think it will fix his issue. The UVC has a build in screen that shows up when no input signal is detected. That's what he sees. For some reason, his arcade monitor is unable to sync to the 15khz generated by the UVC. Does this monitor even support 15khz? There were some machines that had 31khz only arcade monitors.It's so strange.
Do you have another 480p source that you could use to test? ie. a 360 with a vga cable or a dreamcast with a vga cable?
