Sp33dFr34k
I really don't think the UVC is faulty as it syncs fine via the jamma JVS IO, I think it's something I'm doing wrong. I got up this morning and it occurred to me what the problem might be, 99% sure. I have a molex cable wired from my NVS4000 PSU for power, and a VGA cable in parallel on the 15 pin AMP UP, so I don't have to mess about with a jamma passthrough adapter. BUT, seeing as VGA allows for several ground connections via several pins, and I made that parallel cable quite some time ago, I'm pretty sure I used a different pin for ground. The reason being it wouldn't have mattered if I was going the @opt2not route via the jamma JVS IO, but now I want to go a different route, obviously I forgot about that. Hoping that's the case here as it's an easy fix, even though it'd make me quite the idiot lol.
