hoagtech
You got your lines mixed a little there.since people are talking about input lag: I tested the 32mp58hq with a time sleuth and it adds about 2ms over a crt (iirc 9ms in the center which is where rtings measures afaik. remember that crts have 7-8ms lag when measured in the center!). it’s ridiculously good, probably better than all stock monitors lol
edit: sounds like the 32MA70HY-P is just about the same. seems like a great choice if you're not looking to spend a ton of money. It probably won't have any black bars at all if it's like the 32mp58hq, there is no '1:1' scaling option on that monitor, only aspect ratio options. I can say that 4x output stretched to 4:3 1080p looks pretty good, 1440p would look better of course, but it'll do.
4x outputs natively at a 1080p signal. There would be little to no chance of “stretching” the image as the OSSC outputs the black bars at 1080p and has a viewable 960p image.
960 has a thick border when displaying over 1080p.
If for seem weird reason the set ignores black bar content and stretches that would be a deal breaker as improper scaling would occur.
Your image would share pixels unevenly as well as uneven scanlines.
The reason 1440 is magical is because at 6x there are no borders on a 240 image at 1:6.
I’m not sure if 6x is available on the current OSSC but will definately be supported on the OSSC pro release.
Another benefit of 720p is that a lot of newer arcade hardware outputs at 720p and would not have to internally scaled to 1.5 to output full screen over 1080p.
Hope that helps
