rewrite
Multi Boyz Litigator
Multi Boyz
SoCal
Plug and play aside from a volume pot.
450 takes it away, 500 and I'll toss in the PSU you need for it if your cab doesn't have one already.
Happy to ship anywhere in the world on the buyer's dime.
Honest question, is this kit better than Jammafier + OSSC approach?
it both is and isn't
OSSC is much better than the Taito Scan PCB but the Taito Scan PCB is much more simple/cleaner to install
Jammafier is arguably easier to hook up than the official JAMMA kit harness but the Jammafier solution means the buttons wires are encoded into JVS by the JVS IO and then the jammafier decodes the JVS back into normal wire signals, so it's a complicated and unnecessary process to hook the buttons up to your PCB. conversely The Taito JAMMA kit harness has 0 lag because it's just wires straight through from the buttons to the PCB.
