Mirko
You got it, thanks for posting that
no need to translate, Sega made English language versions of the move strip for the USA and UK markets.Looks good, any plans for a translated version of the move strip?
Our original banana has a 10mm hole to fit a 9.8mmI spoke to Ultimarc and got some specs for the above mentioned joysticks.
The Flightstick version has a shaft with a diameter of 10 mm. It has a hole drilled for fitting the handle 30 mm up from the base plate.
The normal version has a diameter of 9 mm. The length is 36 mm from the base plate to the bottom of the ball top. I assume the threads add 6-10 mm. There is an optional shaft 10 mm longer.
Which one would fit best with the banana? I can drill a hole for the bottom mounting screw if needed. What is the shaft diameter and length from the base plate of the Gundam stick (for comparison)?
That shaft on the stick he’s using has no holes, he will need to drill the shaft for the bottom hole of our og bananaWe also need to know the thread position from the base to the 1st and 2nd set of thread to mount the banana
I see you ordered the OG banana
Have you received the stick yet? If so, have you tried it out anything? I'm eager to hear any conclusions.Just ordered that stick to R&D
10mm shaft bat top
Yes I did, haven’t had a chance look at it yet. Ill get back to you next weeHave you received the stick yet? If so, have you tried it out anything? I'm eager to hear any conclusions.![]()
Everything is available still, when I send out emails, I’ll confirm extras that are not on the order formJust placed an order, did I miss out on the art kit?
Cool! Looking forward for the results of the R&D process.Yes I did, haven’t had a chance look at it yet. Ill get back to you next wee
Both in terms of fitting the banana, but also the playability and similarities in feeling of the original hardware.
