As promised, the guide to install the bios board!
BIOS BOARD FINAL:
Same procedure for ZN1 or ZN2's:
1: Fit bios board to the connector at the back with pins or socket if you prefer.
2: Remove IC 353 of motherboard
3:Remove IC 652 of motherboard (fit a socket for later if you like)
4: Attach from J2 of the bios board to the following pin pads of IC353
BIOSJ2 -BOARD353
1- ---------- - Pin13
2- ---------- - Pin15
3- ---------- - Pin17
4- ---------- - Pin19
5- ---------- - Pin22
6- ---------- - Pin24
7- ---------- - Pin26
8- ---------- - Pin28
9- ---------- - Pin10
5:
Bios rom used can be 27c400, 800 or 160
For 27c400 Pin 1 of the socket is empty and resistors / switch not fitted - you can load 1 bios.
Bypass capacitor optional but it's nice to have
For 27c800/160 switch and 2 10k resistors needs to be fitted - you can load 2-4 different bios on switch.
Done!
DO NOT WIRE UP THE BACK CONNECTOR FOR V1 WITH THIS GUIDE, ASK ME ABOUT IT FIRST.
DO NOT USE BIOS V2 board (ask me for a replacement final ver if not already fitted...)
Any questions about installing etc, please add below so it's all in one place
BIOS BOARD FINAL:
BIOSJ2 -BOARD353
5:
Done!
