Ok. You need to rewrite the CF card. Seems there is some corruption of the game image. Download NaomiCF and the game image. Install NaomiCF and run as administrator. If you download the version available for free just hit Register button to enable full mode. Then select the game image, Drive letter that the CF adapter is assigned, enter the four digit code written on the back of your card, and hit flash.
I recommend a clean boot of your computer beforehand. I've seen a clean reboot fix bad CF writing just recently. Corruption can happen a few different ways but the wo most common are: 1--A bad write to begin with and 2--pulling the CF card out or installing it while the adapter is still powered.
Give that a try.
Give that a try.
