DJLC
Saint Louis, Missouri
Does this exist? Is there a way this is compatible with the Dark soft Multi by chance?
Hi, has anybody made this to work? I tried it, it supposedly created the rom correctly, when selecting it on the multi it flashes on the multi but when starting all I get is a single color screen (sometimes very dark blue, or very dark green or very dark grey), and nothing else.
It works in HBmame, so you should be able to get it running. I don't know anything about the multi though.
Thanks, however the ROM file used for MAME is different than the one used for Darksoft's CPS2 kit, so I'd like to have information regarding the ROM used for the kit.
Hi, I finally solved my problem. It seems there was some issue with the IPS patching that the Java application did not catch (I followed the guide from https://github.com/originalgrego/FinalFightAE-CPS2-Installer), so the roms were created corrupted. I repeated the procedure on a different machine and now everything works (at least until stage 3, I have not tested the whole game yet). For reference, the SHA1 and MD5 checksums I got for the working roms are:
Code:
[user@laptop ffae]$ sha1sum *
ed48ea54d85b822fa354d145aaef42e632886d37  ffae.01
62b29c9def4f474e7b25e88c0900a31df1bfecb8  ffae.02
8e9dfcd1d44f792cff4b13f8b8f73aa8f9b0a2ec  ffae.03
4a4cf19422f4f0fc66ce18ea082320c5adb59750  ffae.05
ec9e1be10bba4c3b8bf35fca821cd7f4025dfb4a  ffae.07
f7155a41d4fdbcdd4e626b86de18c391125298e3  ffae.09
6df4aa177a38407814a35a3560da4e9c301b3fa0  ffae.11
eff33c65a4f3862c231f9e4d6fefa7b34398dbf2  key
867e0090555fcb077a7ca5ce891002bd62da2082  NAME
[user@laptop ffae]$ md5sum *
8ad56ab80f92c59e90dc1cfa6b1c8a03  ffae.01
7804da11dbe1fdabf37e781ca7162c2b  ffae.02
806b51fa1feaa57c479a71d987179b52  ffae.03
dca89700796b93dbd922f6715f443ee4  ffae.05
83c08c489ba96396a1b5eac7956944ef  ffae.07
04c82757b9b032e48b49050430c5d414  ffae.09
1efc55dee7abbd77096110007adb00c1  ffae.11
0762a515ab26e0a9837fcadbe42f0712  key
0aa907b6db3018253c573a4a4ed7d453  NAME
[user@laptop ffae]$
Finally, I am using a DS kit with no support for encrypted roms, so this should work anywhere.
Code:
[user@laptop ffae]$
I'm glad you figured it out. I can't wait to try this. Need to add it to my list of things to do.
where do you find ffightae.key? I was trying to get the CPS1 game to work in HBMAME. I only have a phoenix.key that's not the right file size (20 bytes instead of 128 )
people were saying to get the B-21 file from 3 player CPS1 games, I saw no such file in the rom sets? unfortunately with my medical issues that need attention now Darksoft or Mister aren't in my budget right now.
File is attached.
Not a copyright issue because I created these HBMAME CPS1 key files.
  • ffightae-key.zip
Doesn’t generate a working rom for me managed to cobble together a copy that works in MAME but not sure how to make it work on my DS as I’m pretty sure the version on my DS is bad as the one the jar file spits out does not
If you followed the official guide to generate the roms, then at the end you will have a "results" directory with the correct roms for DS multi, HBMAME and mister.
