It seems @Mrhide is using the same exact file without issues, so I'm not sure?Maybe some leftover copy protection?
I have mine in a cart shell but leave the screws out.@Fluffy I've got a V10 here.
And yeah, the thinner boards are harder to get set in there properly without a cart shell (been removing and testing so often it wasn't worth putting it on). Easy to end up with screens like @buffi posted above. Work nicely in a cart shell though!
Another idea: What speed of EPROM are you using?@Fluffy I've got a V10 here.
We're running different games, have both tried different motherboards and yet we're having the same issue, it has to be related to something on the PROG board.Got a second PGM motherboard today (not related to this, just traded for another a while back and got it today) and same results.
Just to confirm, @Mrhide you have a working boardset off of the file you compared mine with, right?
Don't know how this'll be helpful, but I'm down for anything at this point! Hold on and I'll get some up!upload board pics?
Good point, you did confirm we're both using the same PAL. I'm going to try an alternate PAL!Different games, sure, but espgaluda and ketsui both use _esp for a pal (or can, anyway). But others seemingly have them working, so who knows!
I wanted it to fit in the case, damn it. lolYou've also ruled out the other thing I was worried about: sockets
I'll give it a double check, can't hurt!PIN PU. There's a blob of solder in a nearby via and an adjacent and separate trace where possibly the solder mask has rubbed off and created a possible short?
