Ah good to know! I could still modify my Top3000 for non Jedec and try maybe. I’ll look into that equivalent. Do you happen to have the ref at hand by any any chance?
mx27c4100
Did not try programming the 27c4000 as that chip yet though. Might work if you ignore the device ID error.
Thanks, I was about to edit to ask if it was the 4100 ;)
Tried its profile and same issue sadly :/
The TOP3000 can do 27C4100 and 27C400.
27C4000 and 27C4002 are problematic though.
I also ordered MX27C4100, let's see. Kinda bummed that Eetools messed up the 27c4000 support, since both the Topmax and Chipmax are struggling. I'll try reaching out to their customer support, who knows!
Honestly apart from an obscure Chinese programmer I had never ever heard of before, only high end programmers can do 27C4000 and 27C4002.
Those two devices use "non standard" Vcc/Vpp compared to any other one in the 27C range.
Isn't 27C4000/4002 a 27C4096 equivalent?
MX27c4000 is a 32pin equivalent to 27c020
HN27C4000G is 40pin equivalent to 27c400
27c4001 is a 32pin equivalent to 27c040
27c4002 is a 40pin equivalent to 27c4096
EDIT: Fixed
Double wrong.Macronix MX27C4000 is equivalent to 27C040 (32 pin 4Mbit JEDEC EPROM) but Hitachi HN27C4000G is same of 27C400 so 40 pin 4Mbit EPROM device with MASK ROM pinout.Always best thing to read datasheets before :)
you're right I was confusing 4100 and 4001
No problem.I found that also programmer manufacturers like EETools made a lot of confusion among JEDEC and non-JEDEC device like 27C1000 and 27C1001.This is because some devices have been called with same name but different pinout.
.i found that also programmer manufacturers like EETools made a lot of confusion among JEDEC and non-JEDEC device like 27C1000 and 27C1001
I have found this too :( you would think with the price they charge for these devices they would have got it sorted by now.
Some years ago I sent EETools a message and they fixed the bug in the software of my ChipMax2.Before the fix they totally messed up support for 1Mbit non-JEDEC EPROM devices.
Anyone tried this conversation and owns a ChipMax2?
Everything went smooth except programming the Hitachi HN27C4000G. I bought 10 of them through BuyICNow, and all of the 10 results in a "Program Error" at about 3 ot 7%.
I tried to download the romset though different sites, but none of them (sets or the 4 different possible files for this chip) worked :/
Maybe there is voltage drop (possibly due to dirty IC legs)? I'd try setting 13.5V in the programmer.
Disclaimer: I'm not an expert so take my advice with a grain of salt.
While not the same programmer I have a Stager vSpeed which is... temperamental at best with 27c4000. I actually had to up the vpp inside the configuration file by 0.25V increments until it finally started programming them. I think mine's either 13 or 13.25V, not able to check.
I'll try this!
In the meantime I contacted EETools about the issue, and here is their answer:
EEtools said:
Please send 1 failed chip and your binary file and we will investigate and let you know what the problem is. We moved so, please
send the chip and the file to 881 Yosemite Way, Milpitas, CA 95035 in attention to my name, Cheryl Park.
Thank you,
I will do this and report :D
Let us know what EETools says. I've had the same issue with those chips refusing to program with my ChipMax 2. They do program correctly with my Wellon VP-390.
Sent the Hitachi 27C4000 to EEtools today, now wait and see!
In the meantime, I used Macronix MX27C4100-C and the conversion works perfectly :) Thanks all for your help!
