A
Apocalypse
Huh, for me?... I'm curious now.And Apocalypse - have some hardware for you arriving in the same job lot as the long boards, it's no irem tho before you get excited
Any game is a good donor for the multi, you only need to worry about donor rom board if you are converting.I didn't followed this thread before, because I'm not that interested in conversions as in multis, but after the Hammy post on my "Multi List" thread, I've became curious about it and I've just read this thread.
Now following it too
I'm interested in a multi of this, if finally it's done
Which game should be a good donor for this multi?
I would say the cheapest options would be Super World Court, Bakuretsu Quiz Ma-Q Dai Bouken, and Nettou! Gekitou! Quiztou!! (Quiz Island)Which game should be a good donor for this multi?
So for the multi, long/short doesn't matter? say a SWC could play all games once you are done? Awesome, I'm still looking, haven't seen anything yet though. Make sure I'm still on the list for this one though! This might be the only multi I'm in the top 10 on the waiting list!I would say the cheapest options would be Super World Court, Bakuretsu Quiz Ma-Q Dai Bouken, and Nettou! Gekitou! Quiztou!! (Quiz Island)Which game should be a good donor for this multi?
I've found each of those for under $50
Emeraldia, Cosmo Gang the Puzzle, and Knuckle Heads are the next cheapest, usually anywhere from $80 to $120
Fighter/Attacker, Numan Athletics, Tinkle Pit, and Exvania are all the most valuable games on the platform.
X-Day-2 is another cheap game that might make a good donor for a potential multi, but it's not suitable for a conversion because it has a unique ROM board.
presumably the multi would replace the whole ROM board. but this is still technically conceptional so nothing is guaranteed.So for the multi, long/short doesn't matter?
I'll need to socket another ROM Board to test it outTinkle pit is patched now 100%, video + roms uploading tonight
Had all kinds of problems with it however got down to a few nops in the end.
These things are seriously unreliable but I found that most of the failures I've run into have been related to the caps, either they leak and erode the sound section, or there is one off on it's lonesome on the other side that likes to kill the little voltage monitor IC which prevents the board from booting, if you by pass the chip and install a button in the unpopulated location you can manually reboot the board, or just replace the cap and IC.Had 2 motherboards go faulty in testing, very fragile hardware, the more it's moved the worse it gets.
dude technically this thread isn't even about the multiWill there be another post to get on a list for this multi, or is it this thread, or is it too soon?
https://zenmarket.jp/auction.aspx?itemCode=k339100907Assuming your Donor board is a Quiz Ma-Q on a short ROM board.
