This was finished, until I heard about DFO recently (and then after I heard about that, I found a pure digital HDMI mod that I'd love to try one day - maybe I'll buy another board to experiment on).
But for now, here's my pride and joy, housed in a Hammond enclosure that's been used lots of times before by many people (including a red one I did last year but I made a few mistakes on). EDIT - model 1455T2201, I mount the end plates straight onto the the main enclosure - without the plastic bezels, for no reason other than I prefer the look.
I decided to try and mount ports and sockets without any visible fastenings. I have some build photos, but it's pretty simple - the DB15 sockets are screwed into grooves that are on the inside of the case.
I wish I hadn't cut the DB15 sockets central, I would prefer they were offset to the right, with the power button (with built in LED to the left), but I'm definitely not making another.
Simple Stereo RGBS socket on the back (Deltron brand), with power socket and reset button.
Cartridge connectors are secured to the underside of the case via brass spacers.
Here's some of the innards (work in progress)
Here's the brass standoffs, with fibre glass washers to protect the board.
Power socket attached via screws to the inside of the case (black plastic sheet in place to protect PCB when I moved onto soldering the wires in place), and one DB15 secured.
Side view, CR2 battery mounted in holder and secured to bottom of case
Still to do:
Cheers
Pete
Thin plastic sheet cut to fit inside the cart slot.
(You might spot the NeoBiosMasta with VMC installed in this photo, the UniBIOS is a licensed one which I programmed myself - hence a different label on it)
Still to do:
- Tidy up wiring, also make it possible to remove the board completely without the need to desolder anything (for unibios upgrades).
- Try DFO to fix Sync Frequency.
- Try 7374 Amp to check RGB levels?
- HDMI mod? Details here, here, here and here, I've ordered the parts, just not sure if it's beyond my skill level at the moment!
Cheers
Pete
