Home Arcade System
After a long break, I've finally reopened the store!
The HAS is now available with a proper enclosure in three colorways. Printed at a 0.1mm layer height to minimize visible 3D printing lines (each case takes +3hrs to print :S).
Stock is limited this time, so grab yours while it lasts - https://rgbslab.com/
Thank you!
Worth the Wait! 👍
@RGB I have a question regarding ESD safety regarding these enclosures. I am assuming these are printed in PLA or Nylon which are insulators by nature, will this not cause an issue regarding ESD ? (I have limited knowledge of electronics so please forgive if I am missing anything obvious here)
Reactions: RGB
The risk of static charge buildup is about the same as with the acrylic plexiglass case. Both can build a small charge if you rub them against something like fabric, which I wouldn’t recommend :) You will be the most likely discharge point when you touch it, too.
