here some good resolution
In order to find the missing connectors you either need to get a logic probe with a pulse function or a set of Dupont cables and start shorting inputs until you find them while looking at the JVS test screen on a NAOMI.
Received today 2x2GB Kingston KVR667D2N5/2G, 240pin, 667 MHz (PC2-5300), working fine !
no it wont work on an everyday pc.
check out YAJ for a ttx2 quite a few there for around $150 usd then add another ~$150 usd for shipping and fees. might be a bit cheaper shipping for you being in the philippines
A clean dump of SSFIVAE 1.3. has popped up but is "unplayable" .I dont think it is too hard to make playable I wouldnt have the faintest idea though.
It would be nice to see this implemented to the multi.
Everything is "playable" on the multi. I think it was deduced for v1.3 that it was trying to contact the NESYS servers and would not go past the initializing message. If someone wants to patch it out and make it playable, they're able to do so. However, there really is no benefit to this as there were no balance changes done to this version. If you want balance changes then you'd just need to get 2012.
I'm having some trouble with a few non Type X2 games running on the Multi:
Arcana Heart 2.1
Arcana Heart 2.6
Arcana Heart 3
Crimzon Clover
Death Smiles II
All load up but no controls work including Service and Test buttons. All other games on the Multi work great. So I figured it was something with non Type X2 games but, Daemon Bride works fine and it's an Examu Ex board. How do I get JVS support working for these games? Also I have this running in 720p and Crimzon Clover is displayed wrong. Thanks for any help in advance.
If it is the same crimson clover that is all over the place boot it up on a PC and change the display settings. You can also remap the buttons if needed, needed to change something myself a while back lol.
Mmm I had that same input problem for those games when I was using a Sega JAMMA to JVS ver2 (black box with audio amp), switched to the Sega JAMMA to JVS Rev B and no more issues. If you are already using a rev B then no clue. Sorry!
Which version of the Multi and what type of JVS do you have ?
I'm ruining version 1.2 Multi.
The JVS is a generic one in my Chinese Vewlix. I guess that could be it but why would all of the other games work perfect?
Try it with a genuine IO, my CAPCOM works 100% with those games.
