Hammy
Enlightened
Is it worth the messing for big striker? That is the question!I think Ill just do the swap and place sockets while im at it. Both cpus need to be replaced correct? So any 64pin 12mhz (or is 10mhz preferred) 68000 should do it?
Also there's no schematics if you fuck up... The pins are all conveniently bent by the factory and the pads / tracks are LOW GRADE.
Chopping it out is the only way, and a waste of a good processor...
It's only the main CPU needs overclock directly under post 1, the sound CPU can handle abuse of the legend of makai hack , and big striker so no point with that.
