Anyone using a CMVS-RGB pcb for MVS SCART/RGB?
@SVM Hi again. I’ve built another cmvs using this pcb and colours are fine but the image is very dark. Have you any ideas on what components I can change out that may brighten up the image?
Thank you.
Cool! To what values did you change them and what MVS do you have?
I experimented with what I had available which led me to putting a 7.5k R1 and 1.5k R2/R4. I was prepared for problems but thankfully it’s perfect.
  • Like
Reactions: SVM
And what MVS do you have? :)
Apologies I’ve an MV1FZS. Not the prettiest, but fully functional. Fully recapped and Unibios installed. 5v mod also.
Thanks for the photos. Now I see, why your picture might be too dark with the standard resistor values on the bypass pcb: You are grabbing the RGB signals before the "final" resistors R17, R24, and R32. When you solder the wires to the other side of the resistors the picture should be fine with the standard resitors on the bypass pcb. ;)
Ah thank you @SVM. Am I ok to leave it as is? I’d hate to take it apart and desolder all those controller connections again.
Hiya guys. :) Mega noob question here: Are 1/4w or higher resistors recommended for use with both SVM's fixed MKL stereo MV1X stereo and RGB buffered circuit? Asking since I seem to have a bunch of leftover 1/8w 0805 1% thick film resistors from another project. Much appreciated, cheers!
