I just used simple green to get what I could, then some Meyer's Rust remover, still had some remnants so I just used sandpaper to get the rest, since the plastic is white I'm basically just removing the top layer and luckily white is still underneath.That control panel came out really good.
I tried getting that rust on pastic off but not 100% besides scrubbing, what spray you use?
As much rust remover as you can use on that under side(clr), then you'll have to use a rust stopping paint, like rustoleum oil paint for metal to seal it.I just used simple green to get what I could, then some Meyer's Rust remover, still had some remnants so I just used sandpaper to get the rest, since the plastic is white I'm basically just removing the top layer and luckily white is still underneath.
I'm finding the most difficulty removing the rust on the underside of the metal control panel where the buttons are
I used sand paper but messing up the finish on the metal. Since there is artwork on the other side i cant really soak it in vinegar. Anyone have any advice on this part?
man this saved my life, thanks this really made it much easier. Now i can get all my buttons oriented the same way and experiment with different colors etc!
You have mounted the two noctua fan at reverse, is not a big issue but...![]()
Didn’t realize these are the same Noctuas for the Dreamcast fan replacement. Since I have an extra I’ll be working on that next. Now that the Blast PSU, Sun PSU, and Naomi 2 all have new quiet fans it sounds like a dream and not like a rickety jet. Thanks everyone for showing me the way on these mods. Bought a noctua for my PC case as well lol.
I thought I remembered the stock ones blowing down at the board which didn’t make sense to me but I mirrored what I saw inside. But it was a while ago so I’m fuzzy on it.You have mounted the two noctua fan at reverse, is not a big issue but...
