Brook UFB in an Orange Diamond Vewlix
Scillianaire
Los Angeles, CA
Has anyone tried to put a UFB into an orange / black diamond vewlix cabinet? One that is natively USBIO. I would love to switch between the type X3 multi and home console play but haven’t been able to run a brooks in there so far as I’ve tried. Worked fine in my blue diamond. Any thoughts?
I’m considering wiring up a separate panel since I have one for the UFB. Might be faster to swap panels than to try and figure out swapping cables.
You have the lemony vengeance solution ,a parallel wire system for using Brook and guenine Taito wire .
With your USB i/o you could do nothing ,you'd better add a fast i/o system instead.
