Capcom "Forgotten Worlds' Spinner Repro by Hursit Official Interest Check Poll
How many would you preorder/buy?
  • 1
    Votes: 33 23.6%
  • 2
    Votes: 89 63.6%
  • 3
    Votes: 5 3.6%
  • 4
    Votes: 12 8.6%
  • 5+
    Votes: 1 0.7%
  • Total voters
    140
I went down the homemade route, and "lightly modified" a few Sanwa 30mm buttons :whoopsie: They're now on my W2 cab, so I went for the Blue/Red combo.
They don't have the same diameter, but adding a rubber black ring around them made them fit snugly and look rather nice (imo)
They could be shaved down a bit more, but I quite like them raised. They are push button spinners after all. And I haven't had to tack/glue them in, even with a youngster giving them a good bashing they've stayed in place!
Screenshot 2026-11-18 165420.png Screenshot 2026-11-18 165407.pngScreenshot 2026-11-18 165436.png
And just in case you're thinking of doing it with the new Kraken spinners, they fit nicely too. I just needed to use a slightly thicker ring. That being said, some of the older buttons I tried seemed slightly smaller. Fractions of a millimeter make all the difference!
Getting a pack of different sized rings is definitely recommended.
Thank you so much for the additional detail. I noticed your panel has the Japanese text on it (yellow ribbon under spinner). Never seen that design offered before.
...I noticed your panel has the Japanese text on it (yellow ribbon under spinner). Never seen that design offered before.
I got the same as djsheep:
Finally got these mounted using a prototype @alberto1225 panel. The metalic finish on this panel is next level!
+1 for the finish. (now feel bad about my rubbish photos and layer of dust on the panel! :whistling:)
I wanted an extra panel to do a couple of different setups at the same time.
Lovely panels, lovely spinners, and makes Lost/Forgotten Worlds great fun to play :thumbsup:
Giving this some play now, and it seems my spinners are rotating incorrectly? Had a similar enquiry from a customer too.
- Spinning to the right turns the character left
- Spinning to the left turns the character right
Very confusing to play. Have checked against Axunworks spinners and those work as expected and follow the flow of the character on screen (right rotates right, left rotates right). Have tested on CPS-1 Multi as well as an original board.
Just seeing if anyone else who had these new spinners noticed the same issue? Checked the harness, wire colours and it follows the manual.
