ArcadeNerd
since there are screw terminals on the MC Cthuhlu EZ PCB can I screw in wires from pads I already have hacked and soldered and not use a MC Cthuhlu chip?
Doesn't worth that way. But you can terminate your pad hacks to a 2x10 pin row. Then plug it into the 2x10 pin header on the JAMMAizer. Or just wait till the pack hacks are ready.since there are screw terminals on the MC Cthuhlu EZ PCB can I screw in wires from pads I already have hacked and soldered and not use a MC Cthuhlu chip?
Good to hear! Unfortunately, my PC only have HDMI ports and I'm wondering if you have or willing to try to see if HDMI to VGA adapter work on JAMMAizer w/VGA Hat? Thanks!Behold!!! I present to you Attract Mode/MAME running on an Egret II MS9 monitor.
I have here a cheap MAME PC with a CRT Emu enabled Radeon HD7350 card. It is outputting a 15khz signal at 0.7vpp. But as you can see, JAMMAizer is amping the RGB levels nicely. Notice how high the whites are (contrast) and how dark the blacks are (brightness). Yet, you can still see the gradient detail in that psuedo-Viewlix image's left arm. You can also see the the wallpaper in the background. Some of you have heard me say, I feel the J-Pac's amp is outdated and produces an image that lacks contrast and that I feel the THS-seriers amps do a better job at amping 15khz RGB than the amp that Ultimarc uses. Here is proof.
JAMMAizer is going to work just fine for MAME-to-JAMMA cab application fellas.
I don't have an HDMI adapter. Not willing to try it.Good to hear! Unfortunately, my PC only have HDMI ports and I'm wondering if you have or willing to try to see if HDMI to VGA adapter work on JAMMAizer w/VGA Hat? Thanks!
I guess no word from Bryan @ paradisearcade about the MC Cthulhu chips?That's all for now.
Not yet. I am going to send another email tomorrow and see if there have been any updates.I guess no word from Bryan @ paradisearcade about the MC Cthulhu chips?That's all for now.
A supergun allows a JAMMA board to work like a console. The JAMMAizer does the inverse. It allows a console to work like a JAMMA board.can these be used on the mini supergun?
