DARKSOFT CPS III Bios and CD Releases
So my standard cart wont work at all with my ultra simm setup, but my scsi cd setup with regular simm works with standard iso burned on a cd. I wanted to eventually turn this into a ultrasimm setup, but the only downside i find with ultra simm is that sometimes background or character ram corrupts and you gotta reseat the simms everytime, ive tried multiple boards / cart arrangements.
Sounds like the cart hasn't had it's bios updated to the Ultra Bios. I'm sure you could PM @Mitsurugi-w or @ShootTheCore and get it updated for you to work on the Ultra simms. I'm sure there are others and some might be local to you, but those two are the ones I can think of immediately :)
Background or character corrupts don't sound right. Is it possible that the simms may need reburning? Is it only on the Ultra simms that it does that? If it also happens on normal simms, then maybe you have a possible buffer chip that's about to die?
Im afraid they do need possibly to be reburned, i also have a corrupt SF3 NG on the simm, its the only game that never loads.
Ultra SIMMs use a new kind of flash chip which requires the latest BIOS for it to function.
I have two setups, one with a ultra bios and the ultra simms, then the other setup has a standard sh-2 cpu with regular simms. Do i need to reflash the ultra bios ?
What does it mean standard SH-2 CPU? Does the SH2 chip have the custom logo or is it a "standard" SH2?. Only ultra BIOS works with UltraSimms, so you can't use an original cart with UltraSimms, unless you reflash it.
Question for anyone who might know - can you burn the Super/Ultra BIOS to a MBM29F016 and use that as a replacement flash, or will the cart only work with MBM29F400?
Thanks!
For my ultrasimm setup its ultrabios flashed, but my second setup has a standard sh-2 cpu from sega saturn, my friend jose cruz @cruzlink2 did the repair. its a tornade cart, and the cpu was dead in it. I think the cart was flashed as superbios, im well aware i need ultrabios for ultrasimm.
heres the full repair.
Hey @Darksoft - would it be possible to release the Region AutoBoot builds of the UltraBIOS that @Mitsurugi-w hinted at last year in this post?
Hi !
Maybe a dumb question, but does a flashed "regular release" SF3.3a will boot using an UltraBios NoCD ?
Thanks ;)
Hi !
Thanks ;)
Are you asking if a cps3 pcb with the original capcom code loaded into the simms will boot and play with a Ultrabios nocd cart?
No it won't.
After years of neglecting of changing my Street Fighter 3 Third Strike cart battery because of life priorities, it's now dead.
Found out last night when i fired my old upright arcade machine seeing the black screen of death, was heartbreaking, feeling like I've just got back from a funeral.
Man...was going to change the stupid battery coming from Florida back to California at my parents house with this.
Now I'm part of the club. If anyone lives in California or is close can you cut me a good deal on flashing my chip with the darksoft super bios? It's the CD version.
