Perhaps Holy pentalogy with preCPS1 (x68000)Well technically it’s the holy quadrilogy!
CPS1, 1.5, 2, and 3.
I don’t really believe it can be but DS said it is possible
@Darksoft said there will be a test point you can solder to on the multi which will go high or low depending on the game speed (set via file in the game folder on SD card) and you can control DFO with thatSo, for the A board speed question:
I guess the way to go will be a DFO?
And either have a manual switch located on the filter board or elsewhere to select the speed?
or have the multi select it for you based on the game and/or have an option to select via the remote lcd?
cool forgot about that@Darksoft said there will be a test point you can solder to on the multi which will go high or low depending on the game speed (set via file in the game folder on SD card) and you can control DFO with that
Are you sure about this? The A board uses a crystal oscillator afaik - so you should be able to definitely replace it with a DFO type device.The A board does not use an oscillator. It uses a crystal. So you cannot use a DFO.
Loooook at all that Darksoft tape!Well, that was fast!! UPS ftw on this one
How much for the darksoft tape bro? PM incomingLoooook at all that Darksoft tape!
So I shouldn’t change my 10mhz out for a 12?
What kind of sorcery is needed?
there is joystick support for FW too right?
There was no way a true cps1 multi could come out without spinner support for FW And it timed perfectly with the @hursit repros.Each version of FW was meticulously modded for joystick controls before Darksoft was forced to include spinner support.
