You need two extensions if you want both player 3 and 4
Will we have to desolder the original dip switches and solder in the wires for the extension cable?
where can I find it?![]()
Got'em![]()
Mouser has them, i put the part numbers in a earlier postwhere can I find it?
I need some like this too.![]()
… found some extras!
If I can find em I'll give em to ya. I ment 250 dollars in cps1 add on parts250 RCA jacks? Thanks!
All of them and 2 of the 1st one. I was gonna patiently wait till u posted thoOh, ok. Which ones will you order?
Do you have pictures of prototypes of these or something cause like... I know I want one of these but don't really know which one.Bottom installed dips --- $25
Dips with remote pcb and 3 ft cable --- $45
When they are done being manufactured I will have the Filter board mounted dip switches. They will be $45 as well.
@Mitsurugi-w Is this something you plan to offer?If @Mitsurugi-w wants to offer them, he'll be the man.
Cable extension (kicks+3p/4p to the filter board) (Qty2) $25Which ones will you order?
Thank youYes but a bit down the line when I can order the parts and pcbs
Yeah I can do it shorter but you might want to keep 3 ft "just in case"Cable extension (kicks+3p/4p to the filter board) (Qty2) $25
Spinner PCB (Qty1) $55
DIPs w/ Remote PCB - 3ft cable (Qty1) $45
Total $125
Could the cable for the remote dip pcb be less than 3ft?
I'm thinking like 1ft (or whatever the LCD selector screen is) would be perfect for me.
I really hope some of you 3D print wizzards will modify @twistedsymphony 's existing LCD case to support/add the remote DIP PCB.
