GeorgeSpinner
Looks awesome. Very impressive.
How are you supporting all that weight on the JAMMA edge?
Neo Geo Pocket game casesLooks awesome. Very impressive.
Following up with this, here’s what it looks like put together. Used the feet Lions sent to offset the top/rear posts to get everything to line up. Not too bad, will definitely do for now.I have a couple boxes of various sized M3 posts and spacers (example). I can most times find a combination that works.
Cool beans, will look for it. Going with the standard "Dash" one from them for now since I can always move it to my stock SF2 setup.
those out yet or was yours for testing? dunno if i missed that somehow
I can find no problems with it, but right now I'm too busy enjoying Final Fight @ 10mhz (as the mighty Capcom intended) to switch again.Looks like @jassin000 is enjoying the test PCB and its working well
What happen when I will play Street Fighter 2 and will have the 3rd controller plugged/attached? When I move for example on the Right on the 3rd controller I make Kick Light for Player 1? Does it work thisway?
So the signals are routed only to 30-pin edge connector on filter boardbut no further, not to MULTI.Yes, they are not routed.
I had made one. If you want I can put the file on my website if you wanted to print it out yourself or contact me if you need me to print one.I finally did the install. Easy setup and I have it in my SF2CE cab now!! This is probably my favorite multi. Amazing job @Darksoft @Mitsurugi-w and everyone else who helped make this a reality.
Does anyone have a 3d print for the DIP switches or how are ya'll mounting it if you put your multi in a cab? I have the LCD selector mounted inside the coin door but just leaving the DIP selector kinda sitting there for now.
