Megamall should be working for sure. Rom might be corrupted.
Megamall!Megamall should be working for sure. Rom might be corrupted.
It's very weird that I play the same game on the lydz multi (daimakaimura Japan resale) and it has no trouble on my problem A board.As far as the faulty A board goes, the amp might be overheating or burning out-try replacing it.
I'm glad it was resolved with the same fix that I used.Just switched the A board and it appears that's what the problem was. It's the same A board type, just a spare I had. Not sure how I missed the previous post about switching A boards, I've been keeping up with very thing posted. Thanks for the help, and for the record, my sf2 koryu isn't working either, neither is mega man. Thanks again guys.
@opt2notFound another SF2HF sound bug during my last stream, this time during Ryu’s Fireball playing Honda’s Sumo Headbutt sound.
https://clips.twitch.tv/MiniatureStylishReubenHoneyBadger-H5YPnVmxBSysNhFm
@jassin000 @rtw Thank you for the suggestion. I'm using SanDisk 8gb. If I keep getting stuck in erasing, I'll find a better microSD. So far I have no problem writing most of the time.Best MicroSD card to use is Samsung Evo+, runner up Sandisk Extreme Pro.
Avoid Kingston, PNY and other "cheap" brands.
Wouldn't you rather have no problem writing any time?@jassin000 @rtw Thank you for the suggestion. I'm using SanDisk 8gb. If I keep getting stuck in erasing, I'll find a better microSD. So far I have no problem writing most of the time.
I think I got some sound glitching on the first boss of final fight usa (sodom?) where I was hearing voices from a bunch of characters including a girl character? Not 100% sure, no capture, but maybe worth a mention
PAL chip replaced on A board.Greetings! Running into some issues
C-Board: 92641C-1 with the B21 chip, no battery, no mod
A-Board: 89626A-4 with 12hz crystal, all dip switches turned off
SD Card: 64gb SDHC PNY
I soldered the wires, installed the mult, loaded a game and then nothing. I see a black screen. Sometimes when I load up a mono audio game, I might hear something play out, but that's it, not even the actual start up sound, just some random audio.
Not sure what im doing wrong here =(
