PAL chip replaced on A board.
Did you test the A&C boards to work before installing the multi?
SD card formated correctly? on Windows or Mac?
Yes, pal chip replaced on A board
Yes, tested Multiple Dash A boards with a combination of B Boards (Final Fight, Area 88, SF2 Hyper) and they all work
SD card formatted to FAT 32, on windows.
me == sad panda
So! 2 things!
1. Do not solder at 2am.. It turns out one of my solder joints had too much and was making contact with another solder joint and caused issues
2. Use flux core solder.. after i cleaned it up and used flux core solder everything came right up
Sorry for the noise! this is an awesome multi! gonna go enjoy some knights of the round!
But I am seeing an issue, perhaps someone else has seen?
I can't really play my multi for any length of time. ever game I've tried after about 20 minutes, gets this "ADDRESS ERROR" on the screen and locks up. I have to power off and on and I can play again.
Im not sure if this is something to do with my MicroSD card or what? but it seems to happen with every single game that I play.
Address error seems like the C-board could be dropping the key?
Did you need to reverse a modification on your C?
Do you have another C-board to test with?
Even a B21"sf2ce" C-board could be used to test games like SF2CE/HF, Final Fight 30th AE, Strider Trainer (etc).
So this C-board that I bought from a reputable seller to not have to deal with retrofitting an existing one that was hacked is .... hacked right?
Do I have to unlink these 3 pins and fix the cut traces or do I leave them like that since they are all linked to GND anyway?
*sigh* thank you.
*sigh* thank you.
100% that is a modded C board.
@rtw :
92641C-1.
so
These "Good" Options will work, however you will be limited to only using "decrypted" ROM sets.
It's possible that the "Modified" options above can be "un-modified" to return them to their original key-writing function (allowing you to play encrypted ROMs).
Strange mod, but if pin 45-47 are GND you should be good to go.
Here is a quick picture of my A board, in case anything else needs to be checked. Im not sure of the CPU next to the crystal is 12MHz?
