I wanted to bring up a problem I had. I first tested everything with a "normal" mobo. Everything was working then I swap with a repaired mobo. It seemed to work so I installed everything on it (with addons). This is a typical Chinese repair / overhaul board:
It works perfectly with authentic games and conversions but there are audio issues with the multi... On some games (notably
Ghouls'n Ghosts and
Strider) the music cuts out after a few moments of play. Nothing serious, I quickly identified the origin of the failure but my Remote Dip was soldered on it and it's painful. I'm ill-equipped for that and I damaged the Remote connections by desoldering (fortunately the mobo is fine). I asked Mitsurugi if I could reorder the soldering part (waiting for his answer).
So, if you have this kind of A-board, test everything before you start
