war3zlod3r
I flashed the program ROMs with decrypted set on avalaunch’s website and got a solid blue screen, shouldn’t it boot?Just program ROMs
yes you can. Just make sure that each folder has a file called key that is full of 0xFF bytes.Successful install of the old multi!!!! So excited! Now to try and update the firmware, I can still run decrypted roms on the new firmware with wires installed right?
No, you don't need to remove it.Does the SW5 wire need to be removed before firmware updating via SD or just discconected from the B Board?
you were right update went smoothly, I didn't wanna solder directly to the pads and Arthimus' QSB's have been out at his shop for a while now so I order a couple from OSH when that comes in I'll pull the multi off and add the QSB and wires! Thanks for the info everyone sorry if I asked a bunch of noob questions.If it's from 2017 it should have the bootloader but may not have the key writing firmware.
You don't need the discovery programmer to load that, it loads from the SD card
