Nothing much to report at the moment.
I think I have my code cleaned up and ready for initial release. I'm on point to ship a V2 test unit to a forum member.
After having assembled a couple of V2 units, I'm kind of wishing I had handled the placement of the SD module differently. I was stuck within an unfortunate size limit in Eagle that lead me to planning for the module to be installed on the bottom of the board, except that the orientation means that the pins that come pre-installed in the module are on the wrong side and have to be desoldered. It wouldn't be a big deal if I could find these modules without pins installed, but I haven't come across any.
There is the potential to install the SD module top side with the stock pins, if you forego some optional input and output headers.
Ultimately I'm wanting to do a V3 revison in Kicad where I won't have size limitations and can place everything in a more ideal location, but not sure when I will get time to work on this. It will end up taking a long time because I will likely need to re-create all of the assets from my Eagle design.
I'll probably move forward with the V2 release with the plan that the eventual V3 would be 100% the same components, just layed out differently.
Oh... and I haven't found any nice way to fasten the SD module to the board. I can't find inter-board connectors small enough, so I'm left recommending hot glue.
