Talk to @Mitsurugi-wDAMN! I'd buy 3 of these "Filter boards" right away! I have 3 CPS 1.5 pcbs missing the filter board.
The multi will automaticlly reprogram your B-21 to any other configuration, the battery must be removed though.
Yep, exactly. I’m sure someone will have a roll-up pack ready to go with all the goodies. As I mentioned before, there’s over 170 different sets currently being tested, different regions, revisions, hacks, etc.This is awesome! So I imagine it's like CPS2, where we will be able to run all of the original romsets and regional variations?
I highly recommend for everyone to just buy / source a suitable C-Board if they don’t have the skills to revert the mod. It may look simple, but the pins are very fine and fragile.
COULD YOU SEND ME THE LINK TO THE TOPIC FOR BOARD C REVERSION?A placa-mãe é a mesma que estou usando (Short Dash 12MHz). Esse C-Board está certo com a bateria removida, entretanto você deve desfazer o mod e reverter ao seu estado original (remova o fio, reconecte os pinos) para que funcione. Há outro tópico aqui com mais informações sobre isso.
Eu recomendo fortemente que todos comprem / adquiram um C-Board adequado, caso não tenham as habilidades para reverter o mod. Pode parecer simples, mas os pinos são muito finos e frágeis.
very difficult and complicated. where can i buy a c board ready to use in multi?INFORMATION IS HERE. BUT NOT SURE IT COVERS THE STEPS EXACTLY FOR YOUR C-BOARD: https://www.arcade-projects.com/thr...a-90631c-5-battery-backed-b-21-c-board.13116/
45/46 to gnd = battery powered
Motherboard is the same one I’m using (Short Dash 12MHz). That C-Board is right with the battery removed, however you must undo the mod and revert it back to its original state (remove the wire, reconnect the pins) for it to work. There’s another thread on here with more info on that.
WHAT FEE WOULD YOU CHARGE TO PASS ME STEP BY STEP TO REVERSE THE NECESSARY MODIFICATIONS TO MY C-BOARDI could revert the C Board mod for a small labor fee for folks if need be.
I mean the multi featuring cps1.5 implementation has no precedents, wasn't even something to take for granted and everyone so inappetent about it makes me think nothing is good enough here, all great efforts from the creators seem to be dissolved because... I don't know someone found the multi doesn't fix his life lol.Yep, I doubt you could notice it at all @r-type
I used the @aje_fr Multi for a year on a Dash board prior to this multi, played a bunch of 10MHz games. Played the whole library actually many times over.
Wouldn't know the difference whatsoever between a 10MHz and 12MHz game. Who knows, maybe some stuff was playing slightly fast, but didn't bother me. It's not worth getting caught up on and I just urge ya'll enjoy the games. If it's concerning to ANYONE to the point of obsessing over it, just grab a 10MHz and a 12MHz board and play the games at the 100000% perfect clock speed they were designed for. There's no real other way at this point to guarantee perfection without doing that anyway.
Also, if the multi doesn't come with a Forgotten Worlds spinner connector, that's not the end of the world either. Just grab the repro spinners from @hursit or new spinners from @axunworks and hunt down a Forgotten Worlds PCB, or even better, just stash them away until the multi does support them
There's too much fuss these days over correct speeds, pixel perfection, what's missing, what's not right and not enough fuss over actual gameplay IMO. I grew up playing on RF and composite and if that's all I had today, I'd actually still enjoy my time playing whatever I could get my hands on.
I've seen hardly any talk about the awesome library of games on this thread... instead it's just a bunch of worry for no real reason when the final annoucement for the multi hasn't even happened.
Anyhows, how about the Top 5 games you'll play the most on the system? For me it's been:
1. Strider
2. Cadillacs & Dinosaurs
3. The Punisher
4. Ghouls & Ghosts
5. Street Fighter 2: Champion Edition
