Brentradio
The Neo Geo Multi SD Card Compatibility ThreadTried replacing the SD card with a different brand? Maybe Samsung?
Did you put in a fresh battery ?3 times out of 5. Everything works fine when flashing and playing games. However, I'm still getting the "No Games Found" error every now and then, and almost always on the first boot after not using it for some time.
Also, when booting the cart with new game flashes or even from a cold boot, sometimes it randomly goes to "Initialize File System" again, sits for a short while, and at which point audio in games exhibit huge spikes in volume that cause crackle. If I power cycle, usually the cart boots fine and audio is perfect... Random errors, but any ideas?
They use Windows at work and I'm there on the weekend. If I have no luck, I'm going to try that route, and also wait for the new Firmware/Menu. I'm sure it's something I'm doing wrong and nothing with the cart. Just trying to figure it all out.Macs always seem to stuff things up. Noticed it within the RetroPie community. They just seem to screw up writing to SD cards.
No access to a Windows PC?
I need all the multis!You need to get this multi by the way!
Then you have exactly the same problem that I have, will follow closely ...@rtw -- Yep, got the new battery in, but also had this issue without a battery.
I've tried a Kingston 16GB and am using the SanDisk Ultra that I used to use with the cart. The only other thing new introduced into the chain is the cut trace.
that can't be the source of the problem, unless you cut somewhere around and still I doubt it would have such a behaviour.I've tried a Kingston 16GB and am using the SanDisk Ultra that I used to use with the cart. The only other thing new introduced into the chain is the cut trace.
I was super careful when cutting the trace but even more careful when removing the shell (I read instructions well). The “no games found” error usually happens on first boot. And only happens after random “initializing file system” prompts. It’s nothing major. Just troubleshooting.that can't be the source of the problem, unless you cut somewhere around and still I doubt it would have such a behaviour.I've tried a Kingston 16GB and am using the SanDisk Ultra that I used to use with the cart. The only other thing new introduced into the chain is the cut trace.
You may have accidentally pulled the microSD slot which could explain the random "no microSD found", but not the fact that it uploads properly the flash.img and not the top.
I believe we are looking at a microSD issue here. Try using that dot_clean again and with a different card, one just empty and with the file top in update folder.
Well aren’t I the village idiot right now...of course! Top and flash go together.
Not at all. My cab or supergun output is adjusted in the middle, and I usually adjust the game pot accordingly (usually in the middle). Even if I go down to the lowest audiable setting on the PVM or cab, and the lowest setting on the Neo Geo, it's still the same fart I hear, but just lower. Very strange. It is a newly acquired motherboard, but other carts I have work fine on it.Now that I've never heard before. Do you have the sound pot on the pcb turned up real high?
