Brentradio
I did the same thing!That was because I messed it up myself with taking the PCB in and out of the case to cut that one trace...
Only I did it twice.
As Mitsu can attest to, as he fixed it both times.
Working great now!
Contact @Mitsurugi-w - the starter of this thread for help with this.I don’t really want to mess with the pcbs and soldering - might make it worse...
Is there anyone I can send it to to get fixed? If it’s the SD card slot that seems like it should be easily resolved? Does the case even come off easy?
Not as of yet.Did we ever get support for changing games via the mvs select game button? Either via a pinout or something in the firmware.
It's a simple operation to check the soldering of the microSD slot, check for proper contact and replace if needed. I'm sure any local shop could do that. I'm not sure now who in the UK could do that for you. If you can't find anyone you can send it to me.I don’t really want to mess with the pcbs and soldering - might make it worse...
I can help you with the setup process.I can't finds anything online that can tell me what I'm doing wrong or for that matter a video online that guides you through the set up process for the cart.
True. I didnt check that. I assumed it was fine because i tested 2 other games with it and it worked fine. I will check it tonight and post it here.What’s the voltage reading showing on the MV1B?
4.97V. I will try 5.1V.What’s the voltage reading showing on the MV1B?
No go. I tried as high as 5.2V and nothing. It freezes in "checking games".4.97V. I will try 5.1V.What’s the voltage reading showing on the MV1B?
This is how you fry your games.No go. I tried as high as 5.2V and nothing. It freezes in "checking games".4.97V. I will try 5.1V.What’s the voltage reading showing on the MV1B?
