Mikey107
Hi, my cartridge came today. It's having some graphical issues where horizontal lines are flickering across the screen. You can see them on the Dark soft logo and in the background of AoF3 in the images below.
I'm using a consolized MV1FZ with Unibios 4.0 and a SanDisk Ultra 32 GB microSDHC. I haven't checked the power how would I do that?which motherboard are you using? Did you check your power? 5V at the cartridge edge? What type of microSD are you using? and finally, which BIOS are you using?
PLMK
Consolized? Can you show some pictures of your NeoGeo setup? Including the PSU, please.
Yeah, I can see they've changed quite a bit. I don't have another MVS at the minute to test but I have all of the Art of Fighting and Fatal Fury games and they work without any issues.Yeah, that is a bit far away in many ways from original Hardware. I would say that those glitches come from the PSU or some bad caps in the motherboard, sometimes a bad chip can have that effect too as it introduces noise in the PCB. Do you have another MVS motherboard where you can test it? Does it happen in all games?
I'm using menu 20230322 and fw 20200602_r1169What revision fw and menu are you running?
To me the problem is with one of those mods or a bad part in the motherboard.Thoughts? Is the MV1FS still problematic with the newer carts? Bad caps maybe?
I've seen this behaviour before on motherboards that have problems with some chips, or bad caps.1. Reboots, black screens - The closer to 5V I run, the more severe the reboots get. Sometimes the cart refuses to boot entirely, or hangs when attempting to use hook to return to menu. I had to continue to step down my voltage all the way down to 4.56v which seems to have helped. Even at 4.57v I had some random rebooting in game.
Can you post some pictures please.MV1FS (my only board)
CR2032 mod with new battery
Looking at it they have removed the Neo-Buf chip, could that be the issue?
Sure, if you need me to take more let me know, thanksTo me the problem is with one of those mods or a bad part in the motherboard.
I am using a Mean Well RT-125A with the PSU cover jcmorrisii sells to power the HAS/Mobo:I don't see anthing out of the ordinary there. How do you power that Mobo?
I'm not sure if this feature is new to version 4 of unibios but
with "Disable BootUp HW Test" enabled: the MVS ignores the cart until I do a soft reboot
with "Disable BootUp HW Test" disabled: the MVS acts like Mitsu shows in the youtube video shown in the manual. It recognizes the cart almost immediately.
