SvC seemed to run fine playing through a few levels when doing this. LB2 has the same problem, coin up, start, crashes before character select.Try deleting the three slots then load SVC into slot 1 only and try it out.
I ran into some weird sound crackling on SvC, but after swapping to another game and then re-loading SvC it went away. I've had other games with glichy behaviour do the same. At this point I'm chalking it up to problems with the MV1F(S).Some minor sound glitches running through LB2 and SvC attract mode but otherwise everything is great.
Copied to the first post.There are currently some confirmed issues with certain motherboard revisions/multicarts as listed below. We are working on these issues and
will update you once these are fixed;
- Should you use a MV-1F or MV-1FS, please note that there currently is an issue with these. Quick fix is lowering your 5v to about 4.7-4.8v.
- Should you use a 4 or 6 slot avoid using UNIBIOS
- Some multicarts do show some gfx issues like fixed dots. All carts passed the quality test but seems as some solderpoints were not properly done and have a bad contact originated during shipping. Please PM me if this is your case.
- There is a problem reading files on bigger cards, that we are currently fixing.
Expect a new firmware update as soon as we fix these issues.
Yeah, that looks a lot like what I have too. Harder to tell with the screen you chose to show, does it look like this?Anyone seeing anything like the weird white lines flickering in this:
Yeah it's like that but not as bad on mine, haven't tested thoroughly but so far I've seen it on Blues Journey, Garou and Fatal Fury to varying degrees. Interestingly I didn't notice it on Andro Dunos or Puzzle Bobble. I will get my video capture card going and see if I can capture this stuff better.Yeah, that looks a lot like what I have too. Harder to tell with the screen you chose to show, does it look like this?Anyone seeing anything like the weird white lines flickering in this:
I am using a MV-1A yes, I can try that. If it does fix the issue though is that something a firmware update can fix? I hope so!
No, this is a big red 4 slot, so maybe just a 4 slot issue.Are you both using a 1A motherboard?
Which BIOS are you using? Does it happen in other motherboards?No, this is a big red 4 slot, so maybe just a 4 slot issue.Are you both using a 1A motherboard?
Stock BIOS, no idea about others, only motherboard I have.Which BIOS are you using? Does it happen in other motherboards?No, this is a big red 4 slot, so maybe just a 4 slot issue.Are you both using a 1A motherboard?
Oh man, that's @Darksoft's secret QR code, I think you won somethingI received my Multi MVS today. Unfortunately it will not boot fully. I see a green light on the cartridge, but it only ever shows the following screen:
I have tried with and without an SD card inserted. I'm on a MV-1A with stock BIOS. Any suggestions on what to try?
